madmick Padawan
Posted: Wed Sep 21, 2011 3:28 pm Post subject: 1978 Westfalia Subaru SVX 3.3, Red 9, Porsche 944 Mix |
Time to start the thread for my project it's a 1978 Westy Berlin camper van.
I am putting a Red 9 front end with Porsche 944 Turbo brakes the rear end will have Porsche 944 Turbo trailing arms and brakes.
The real fun part is the Subaru SVX 3.3 engine!
Will keep posting
[/img]
As she was pre-project.
Old front end
Welded new out riggers and jacking points
POR 15 Under coat
POR 15 Top coat
Sealed up and stonechip applied
POR 15 2k Hard nose Black top coat
A fresh coat of paint inside
Red 9 Design turned and lacquered
Subaru SVX 3.3 |
Posted: Wed Sep 21, 2011 10:15 pm Post subject: |
Now we're talking shall be following this one
Looks well protected underneath I should bloomin hope that stays sealed for a few years.
Welcome to the darkside
Great choice of braking btw  _________________ 1971 Devon Bay with 1800 Ford Turbo Diesel Engine (wip)
2013 Scirocco TDI GT |
madmick Padawan
Posted: Thu Sep 22, 2011 2:04 pm Post subject: |
Thanks JP
Latest work modifying the 1986 944 front hubs to fit the Bay spindle.
The bearing races in the 944 hub need to be moved out 5mm on the inner and 3mm on the outer.
Also a 7mm spacer on the spindle to allow adjustment on the taper bearings.
Making the bearing spacers
1986 944 hubs
Slight leveling mod to hub carrier
This will allow the caliper mount to sit flat
911 Turbo disc
Ready to start caliper mount mod |
Posted: Thu Sep 22, 2011 5:02 pm Post subject: |
| Nice project , I did a how to on the 944, rear set up on here somewhere or maybe early bay. Look forward to seeing this one develop |
madmick Padawan
Posted: Tue Sep 27, 2011 9:13 am Post subject: |
| I found your how to on the rear suspension set up, nice job you did cant wait to start mine! |
southcoastcruiser Padawan
Joined: 04 Jun 2011 Posts: 71 Location: South of France
Posted: Wed Sep 28, 2011 6:59 pm Post subject: |
hi
What gearbox will you fit ?
tnierry |
madmick Padawan
Posted: Thu Sep 29, 2011 3:40 pm Post subject: |
Hi Thnierry
I have the original VW 2.0lt gearbox but it will be sent to bearsmotorsport.co.uk for full rebuild, I have spoken to Paul at Bear and we are looking at replacing all the internals
Putting a turbo clucth in.
Mick |
madmick Padawan
Posted: Thu Sep 29, 2011 3:49 pm Post subject: RJES.COM Parts arrive |
Just got my loom and a whole lot of stuff from Richard at rjes.com
Sent 26lb of wiring to Richard and this is all I got back!
RJES Bell housing
Heater matrix and blower
Radiator Housing
Radiator |
madmick Padawan
Posted: Sat Oct 22, 2011 9:21 pm Post subject: Caliper mount |
Finaly got the caliper mount made and everything bolts up nicely
Some 8mm angle iron and nuts
Drill and weld in the nuts
Weld in a 8mm bar and drill mounting holes
Machined down
Painted red to match
Caliper bolted in place
Wheel on looking good
Arty shot
Next on list fitting master cylinder & remote servo.............. |
Posted: Sun Oct 23, 2011 1:42 am Post subject: |
Welcome fella
Were you at Jambo? _________________ The advice you receive on here is worth the paper it's written on.
madmick Padawan
Posted: Sun Oct 23, 2011 7:56 pm Post subject: |
| ElusiveStranger wrote: | Welcome fella
Were you at Jambo? |
Hi ElusiveStranger
I wasn't at Jambo has someone got the same paintwork? |
madmick Padawan
Posted: Sun Oct 23, 2011 8:08 pm Post subject: 944 Master cylinder fitting |
Had to make a wee body mod to fit the 944 master cylinder
944 Master cylinder
Cut out small hatch to allow resevior to fit
Frame for hole
It fits
Cover plate made
Welded in place primed and sealed
Just needs paint |
