2.2 non turbo high idle speed
tuzza123
PostPosted: Sun Jan 15, 2012 9:00 pm    Post subject: 2.2 non turbo high idle speed Reply with quote
1993 2.2 non turbo engine starts easily but high idle speed 1500 rpm
no fault codes are stored
Joel
PostPosted: Sun Jan 22, 2012 1:06 am    Post subject: Reply with quote
Is it just for a bit when you start up cold? or does it idle high all the time?
If its just when cold starting your Idle control valve probably needs a good clean out, they gunk up bad and cause high idle.
If its all the time again it could be ICV but a vacuum leak will also cause high idle.
Other possibly is someone has frigged with the throttle body settings.
there is a bypass screw that will bump up the idle but it should be sealed from the factory.
PostPosted: Sun Jan 22, 2012 1:12 am    Post subject: Reply with quote
Also check the obvious easy option, how's your throttle cable tension? Mine has to be pretty slack otherwise it'll hold the revs up and give a fast idle.
Check it with the cable disconnected.
tuzza123
PostPosted: Sat Jan 28, 2012 12:20 am    Post subject: Thanks it was icv tested ohms as per manual and changed Reply with quote
