Help needed. Got my bay and an engine.
mark230678
PostPosted: Fri Nov 18, 2011 8:37 pm    Post subject: Help needed. Got my bay and an engine. Reply with quote
Ok so picking up my bay next week.
Its a solid rolling project.
I also have a xantia engine 1.9td that i would like to put in.
I am asking for as much information as possible as to what is required, and a how too if anyone has one.
Have searched for las few days and done a fair bit of reading, but cannot see a complete step by step guide, this is why i am asking.
Hope to here from someone soon, currently i haven't got a clue.
I alsoo want to know if it is possible to change from 4 speed box to 5.
As an aside i do have a 110 bhp vw engine as well. But this is ECU controlled so guess this would be a no no.
Many thanks Mark
illzlee
PostPosted: Mon Nov 21, 2011 12:19 pm    Post subject: Reply with quote
hi mark,
where are you in the uk? you are welcome to look at mine for inspiration.
Hello
mark230678
PostPosted: Mon Nov 21, 2011 1:24 pm    Post subject: Reply with quote
Appreciate the offer.
Am in Manchester.
What is required to mate the 2 together?
May well pop down
Think Someone else did it close to me as well.
Have had a proper look round.
Any chance of emailing pics?
PostPosted: Tue Nov 22, 2011 8:38 am    Post subject: Re: Help needed. Got my bay and an engine. Reply with quote
Many thanks Mark
the xantia engine will be easier to wire as it has a fully mechanical injection pump (but may need imobilliser removing from injection pump prior to fitting) making the engine wire to run
the 110bhp vw engine is a bit more wiring due to being fly by wire but my split and last bay were both flyby wire vw tdi so by no means impossible
no point changing from a 4 speed to a 5 speed from a t25 as the 5th in the 5 speeder in generally no taller than the 4th in a good 4 speed box you want a 2.0litre cp box as its got a 4.57 diff and a 0.89 4th so will give decent motorway cruising speed
PostPosted: Tue Nov 22, 2011 8:40 am    Post subject: Reply with quote
you need a adaptor plate and flywheel for whatever engine you decide to use (for the pug engine try famous phil on here)
mark230678
PostPosted: Tue Nov 22, 2011 10:51 am    Post subject: Reply with quote
Think I need to have a proper chatwith you.
You seem to have been there done it and got the tshirt.
Cheers for the info.
Will be pecking your head in the not too distant future if that's ok
illzlee
PostPosted: Tue Nov 22, 2011 12:38 pm    Post subject: Reply with quote
not terribly good piccys, but gives you an idea.
you are welcome to come and have a mooch round my van for inspiration. it's also got a t25 5spd gearbox and linkage.
i'm 5 minutes from j25 of the M1.
Dan Cool
mark230678
PostPosted: Wed Nov 23, 2011 7:05 pm    Post subject: Reply with quote
Is is a simple enough fit, with a T25 gearbox and linkage
I take it the plate is still required
mark230678
PostPosted: Sun Nov 27, 2011 9:21 pm    Post subject: Reply with quote
Is famous phil still active??
Trying to get in touch
Really interested in the fly by wire vw's as have one sat in the garage
mark230678
PostPosted: Sun Dec 04, 2011 2:45 pm    Post subject: Reply with quote
Next question is, after having gotten my engine out of the Xantia, i also have the gearbox attatched.
Would it be possible to use the box and the engine togher????
billy739
PostPosted: Fri Dec 23, 2011 8:53 pm    Post subject: Reply with quote
NO!!
vw box only
mark230678
PostPosted: Sun Dec 25, 2011 8:11 pm    Post subject: Reply with quote
Is that personal opinion?
Or a definitive answer.
Speaking to Phil
Says it can be done...
By mounting engine and joining via driveshafts
