splitbusvanatic Jedi Master
Joined: 08 Oct 2006 Posts: 330 Location: Co. Mayo, Ireland
Posted: Wed Feb 22, 2012 3:14 pm Post subject: Any Advice on Remote Brake Servo's |
I have toyed with the idea of fitting a
direct action(i think that's the correct term) brake servo to help my brakes,
I see MadMick, you've fitted a remote one from VWJim.
I may use the pimped 944 servo on my Golf yet,
Anyway,
I see Ratsport do a remote servo and it's not too expensive..
http://shop1.actinicexpress.co.uk/shops/Rat_Sport/index.php?cat=Brake_Servo__Remote_
looks ok.
Would it be good enough to help my brakes stop my Split 1.6d..?
They'll likely be a vw sourced disc jobbie on front, t25 drums on back setup.
Also.
while I'm asking questions,,
Did any other common car have a remote servo fitted to it.
Preferably one that I might get in a scrap yard..
Thanks As Always In Advance,
D.C. |
Posted: Wed Feb 22, 2012 9:41 pm Post subject: |
Just looking there on Ebay,
PLenty for MG's and such.
I guess I'd need two for the bus..
would we agree??? |
Posted: Thu Feb 23, 2012 7:35 pm Post subject: |
direct acting is always cheaper, will give a better pedal feel and less pipe work hence why all new cars are that type. old mgs do have a remote servo but there single circuit i belive? if you just servo'ed the front i think you would keep locking them up due to weight distribution of van _________________ 1964 rat 13 window deluxe 1Z tdi,
Posted: Thu Feb 23, 2012 11:22 pm Post subject: |
I would Direct Servo it as I understand it's the better of the two.
However my van being a left hooker.
My clutch cable would have to be rerouted. (Isn't that correct)
I've since learned that the MG type are indeed single circuit.
That's taking a step backwards.
I probably will go with the Remote Servo.
Something like the one VWJim sells.
That would be suitable for a a dual circuit.
Am I right ?
So.
It's a trade off I guess.
Is it more hassle to make a direct servo work with a LHD splittie beam.
In a bus with a cable clutch.?
OR
Fit a Remote Servo in my bus and live happily ever after with my cable clutch intact.
Please Discuss.
HeeHee.
Posted: Fri Feb 24, 2012 7:00 pm Post subject: |
my split is lhd but still has a direct acting servo from a golf even though there are a lot of things going on up front with the power steering etc, anything can be done if you put in the legwork  _________________ 1964 rat 13 window deluxe 1Z tdi,
Posted: Fri Mar 02, 2012 1:39 pm Post subject: |
| 13 window deluxe wrote: | my split is lhd but still has a direct acting servo from a golf even though there are a lot of things going on up front with the power steering etc, anything can be done if you put in the legwork  |
God knows I've done the leg work.
Throw me a few pics when you get time.
I still Have MadMick's funky mine sprayed 944 Servo here.
Cheers. |
Wilma 1971 Force Sensitive
Posted: Sun Mar 04, 2012 11:24 am Post subject: |
Hi ..... i have fitted an mg type in line servo to boost the braking on the front of my bay...as i did not have a servo mount on the beam
it works fine and the breaking effort has doubled  _________________ 1971 bay window restored from a rolling wreck
EJ20 subaru conversion
(Parts supplied by the fantastic Richard @ RJES) |
