Connecting a modified Scooby loom to a bay window existing w
Hayleyjosephfrances
PostPosted: Thu Nov 29, 2012 2:23 pm    Post subject: Connecting a modified Scooby loom to a bay window existing w Reply with quote
PLease could someone help me with a wiring question for my conversion. Simple really how and what do I need to connect to the scooby wiring loom to run the gauges at the front on the dash on my early bay window. Alternator light, oil pressure, ignition switch etc.... I am trying to collect all the information before I start the conversion. diagrams and descriptions would really help. Engine is a EJ20 non turbo. Thanks
Mark
Looking forward to reliability and a few less trips on a recovery truck
PostPosted: Sat Dec 01, 2012 11:40 am    Post subject: Reply with quote
What year?
to make the vw gauges work you'll need to connect the alternator light and the oil pressure light.
you'll need to supply the loom with +12V, obviously a switched +12V, then you get into what the ECU will require, ecu memory +12V, vss, neutral position switch, radiator relays oh and you should install the engine chek light too.
and dont forget to install a coolant temperature gauge, another hurdle you'll have to over come.
loads of information in the forum though.
