RE: Split to 9XUD conversion ???
lukus147
PostPosted: Sun Jan 13, 2013 8:44 pm    Post subject: RE: Split to 9XUD conversion ??? Reply with quote
]My first post on VWKD, been using the site for ages for info so thought I better register, I'm converting a 66 RHD split with a peugeot XUD engine, running a 5 rib bay window box. Engine and box are mated, flywheel drilled and clutch sorted, I've cut away the Frame horns and IRS'd the suspension and fabricated the rear gearbox mount,
Has or is anyone doing the same conversion?
Any advice would be very much appreciated :-]
All the gear, no idea.
lukus147
PostPosted: Tue Oct 22, 2013 8:15 pm    Post subject: Split to XUD update Reply with quote
Just an update if any ones interested, have installed my XUD9TE engine, made an exhaust and cooling system using a under floor (between chassis rails) Land rover defender radiator with 16" push, pull fan, ran it up to last weekend, on over heating issues, spot on. coming back out now for a clean and tidy up,
All the gear, no idea.[/i][/b]
splitbusvanatic
PostPosted: Tue Oct 22, 2013 10:07 pm    Post subject: Reply with quote
Sorry for not seeing your first post.
Well done on the conversion.
I need pics.
A lot of them.
