ej 20 sohc na valve clearence
paul_q
PostPosted: Sun May 19, 2013 2:49 pm    Post subject: ej 20 sohc na valve clearence Reply with quote
does anybody know the inlet and outlet clearence for a ej20 sohc?
thanks
martin59
PostPosted: Fri May 24, 2013 11:28 am    Post subject: Reply with quote
If it is an EJ20, then it has hydraulic tappets, & therefore do not have adjustment, but there is a huge lack of information in your post!!
paul_q
PostPosted: Fri May 24, 2013 9:15 pm    Post subject: Reply with quote
hi martin,
the engines from a a R reg 20l injection sohc awd legacy estate. i brought it off of ebay it was metallic blue and smelt of dogs. these are the heads and they have adjustable tappets which i would like to gap before fitting the engine.
cheers paul.
martin59
PostPosted: Wed Jun 05, 2013 1:03 pm    Post subject: Reply with quote
OK, inlet clearance is 0.18 - 0.22mm, exhaust,0.23- 0.27. All settings done cold, which with the heads off, is a bonus!!......
paul_q
PostPosted: Sat Jun 15, 2013 7:37 am    Post subject: Reply with quote
Thanks martin
paul_q
PostPosted: Sat Jun 15, 2013 7:38 am    Post subject: Reply with quote
Thanks martin
