paul_q Force Sensitive
Posted: Sun May 26, 2013 8:40 am Post subject: Wiring advise |
I am ready to fit my loom and wondered if the ecu or any of the other connctions on brackets need to be connected to metal to earth them? I am fitting a ej20 n/a into a earlybay and was going to fit it all under the the rock and roll bed to wood.
Also will a autometer tachometer run ok from the ecu output?
Thanks paul.[/quote] |
Posted: Sun May 26, 2013 12:18 pm Post subject: |
| I have found a thread on ecu's and earth so just need help with wiring the tacho please. |
Posted: Wed May 29, 2013 6:25 pm Post subject: |
If you have wiring diagram you will discover there is a tachometer output to the ecu. It's a single wire, can't help with which pinout it would be _________________ Think......
