Joined: 14 Jan 2011 Posts: 17 Location: Warrington, Cheshire UK
Posted: Thu Sep 05, 2013 10:27 am Post subject: Subaru Loom, ECU, Immobiliser, Transponder, Key etc
I have a full wiring loom from a W reg Legacy 2.5GX with the matching ECU, Immobiliser, Transponder, Subaru Ignition Key, all the relays left on the loom when it was removed. Includes the inlet manifold (phase 2) with wiring, injectors, fuel rails and regulator, wiring from dashboard. The throttle position sensor, Idle Air Control Valve and Ignition Coil would need to be sourced separately (could probably help with this if needed).
