1977 T2B with a 2002 legacy engine 2.0 sohc
Goto page Previous  1, 2
PostPosted: Mon Aug 04, 2014 12:35 pm    Post subject: Reply with quote
Thought so about the batteries. I really like your rad setup, but I didn't want to sacrifice interior space...
so now I am stuck with the underside rad.
anyway, keep up the good work!
splitbusvanatic
PostPosted: Mon Aug 04, 2014 7:28 pm    Post subject: Reply with quote
I love the sump.
How much clearance did you get from modifying it ?
Alan
PostPosted: Tue Aug 05, 2014 10:06 am    Post subject: Reply with quote
hi
the clearance is 34 mm at his lowest
but thats also because the shocks are longer then the previous one's otherwise the sump would be touching the ground Grin
this is the hight i ride with
greetz Alan
1977 T2B with suby 2.0 from a 2002 legacy
PostPosted: Tue Aug 05, 2014 10:20 am    Post subject: Reply with quote
Holy cow. and I was afraid that 20 cm of clearance would still be too little...
Laugh Out Loud Laugh Out Loud Laugh Out Loud
Alan
PostPosted: Fri Aug 08, 2014 5:42 pm    Post subject: Reply with quote
hi
i had to make a modifacation to the inside of the belhousing
the clutch wasen't disengaging al the way when i released the pedal
the problem was that the fork that holds the clutch bearing needed more room so i gave it room Grin
i filed of the aluminium bulge on both sides
i also filed of a litle bit of the back of the fork
btw i used a powerfile Happy
this problem probebly occurred because i sold the gearbox and accedently left my clutch bearing in the gearbox so i bought a new one
and this bearing with the existing clutch didn't fit to wel
when i could use the original bearing it propebly would fit as it is a original maching set
taking out the engine is but an hours work anyway Grin
that was the last one of my modificatins
and then there was the testdrive Grin
https://www.youtube.com/watch?v=UWIs9pCAmVw
https://www.youtube.com/watch?v=GbzdKZmjbv4
greetz Alan
loinfish33
PostPosted: Mon Apr 27, 2015 1:36 pm    Post subject: key and fob Reply with quote
alan help ! I have fitted the engine and plumbed it in , the electrics is been fitted in the ecu is also fitted , but a guy said the ecu is coded to the key and fob . and will not work without them connect ? , only thing is I throw out the key and fob ... is it right that ecu will not work ? how did you overcome this or did u fit the key and fob thanks Adrian hope u are all ok
Alan
PostPosted: Mon Aug 21, 2017 8:14 am    Post subject: Reply with quote
sorry i didn't reply sooner you probibly already know the answer but i used the suby contact with the key.
Page 2 of 2
