Temperature Gauge Accuracy
Sydney
PostPosted: Wed Aug 20, 2014 9:40 pm    Post subject: Temperature Gauge Accuracy Reply with quote
My water temperature gauge became erratic and I couldn't fix it so I bought a VDO one with matching sender unit. Out of interest I tested the gauge before Installation, with the sender held in a pan of continuously boiling water at sea level. The gauge would not read above 95deg C.
Has anyone else tried this test and managed to get their gauge to read 100deg C?
Sydney
PostPosted: Sat Aug 23, 2014 2:34 pm    Post subject: Reply with quote
I've now tested another new water temperature sender and gauge the same way and got a reading of 94degC.
Does this mean that when my gauge has occasionally reached 100degC, the true temperature has been 4 or 5 degrees higher?
Or is there some rational reason that the boiling water test gives a reading of below 100degC.
milkabus
PostPosted: Tue Sep 09, 2014 6:04 pm    Post subject: gauge test Reply with quote
Well id say get a temp probe and pop that in the pan to compare against
