Subie Newbie - EJ22 into Dunebuggy - radiator connection q's
danielzink
PostPosted: Sat Sep 20, 2014 5:39 pm    Post subject: Subie Newbie - EJ22 into Dunebuggy - radiator connection q's Reply with quote
Hey All,
As the title says...I'm a newbie to this Subaru swap thing...so be gentle..please...
I'm currently working towards getting an EJ22 installed into this open buggy/sandrail:
I have my motor...harness is out being modified...
I'm tring to work through radiator placement, tanks (if needed) etc.
I understand the connections #1 and #2 (as labeled):
My "connections" questions start here:
This is a summer time/fair weather only buggy - with absolutely no provisions for heat....can I just loop connections #4 and #5 back to each other ?
And lastly - where will connection #3 go ?
Do I "have" to run an overflow tank ?
Thanks for any and all help !
Dan
www.danielzink.com
mackaymanx
PostPosted: Sun Sep 21, 2014 9:45 am    Post subject: Reply with quote
You have to loop 4 to 5.
3 should go to filtered air.
danielzink
PostPosted: Sun Sep 21, 2014 1:59 pm    Post subject: Reply with quote
Laugh Out Loud
How embarrassed am I.......
I'm the one that pulled the motor and wiring.....
You'd think I would have known that....
I set the snorkle back on the engine and what do you know ???
Thanks again !
Dan
www.danielzink.com
Jzgerman
PostPosted: Tue Dec 01, 2015 8:13 am    Post subject: Reply with quote
You have the ability to very high, I need you now.
