cooling pipes question subaru Ej20 beetle conversion
atlas2l8v
PostPosted: Wed Jul 22, 2015 1:11 pm    Post subject: cooling pipes question subaru Ej20 beetle conversion Reply with quote
Afternoon folks
Just a quick question re the cooling pipes people are using on their conversions.
Ive read all about copper/steel/ali etc and wondering if you are able to use something like "stainless steel flexible exhaust pipe" along with a good coolant to protect against corrosion ?
http://www.ebay.co.uk/itm/38mm-1-1-2...item19ee4324df
Or am i better off sticking with steel tube or copper
PostPosted: Wed Jul 22, 2015 1:33 pm    Post subject: Reply with quote
I did everything using regeluar coolant hoses. Rubber, flexible, easy to cut. only the connections were made, using steel connectors.
So far, so good! available at many diameters, available at any length.
How are you gonna make proper, watertight connections with the flexible exhaust? Welding?
atlas2l8v
PostPosted: Wed Jul 22, 2015 1:45 pm    Post subject: Reply with quote
thanks for the reply..
Was thinking of it being in one length as its flexible to run along the shape of the beetle under the car from the rear to the front
but yes weld if needed, using the rubber wont it split if its caught ?
PostPosted: Fri Jul 24, 2015 12:39 pm    Post subject: Reply with quote
Any thing will split if it gets caught.
Is that exhaust flexi watertight under pressure? Also what grade is it? It may still corrode, ever had a long life stainless exhaust made? They still corrode.
I've gone for copper tube. All is fine but I use a quality antifreeze.
atlas2l8v
PostPosted: Fri Jul 24, 2015 9:12 pm    Post subject: Reply with quote
thanks Kai
Will go with copper
PostPosted: Fri Jul 24, 2015 9:33 pm    Post subject: Reply with quote
I used 28mm copper tube for main runs front to back. You can get plenty of reducers both in copper or silicone. I also had a pipe bender for the copper AND I believe you can get flexible copper tube, dunno about 28mm though.
1303Steve
PostPosted: Tue Jul 28, 2015 10:11 am    Post subject: Reply with quote
Hi
I used 1.5 inch stainless tubes and had a kink put in them so that they line up with the depression in the chassis for the heater channel bolts then I had more 1.5 inch tubes made up join the motor and radiator, all my joiners are straight 1.5 inch radiator hose. I built a 2.1 WBX Beetles in the 80s and I made the mistake of using many different shaped hose, too much trouble to carry spares.
Steve
STI powered 1303 now running
G50 box, Boxster/944 brakes, Adaptronic 1280E ecu, PWR intercooler etc
View user's profile Send private message Send e-mail AIM Address
