filling the oil in a bay window bus with no top access hatch
trev
PostPosted: Fri Aug 05, 2016 11:03 am    Post subject: filling the oil in a bay window bus with no top access hatch Reply with quote
I'm 90% finished the VW 1.9D conversion into a previously 1600 bay window bus. It's the engine and box conversion I took out of my van when I went TDI. My van has the over-engine access hatch in the rear luggage area. I used to just pop-off the crank case ventilation valve on the cam cover and fill through that hole but I have no access to it now in this new bus.
I'm thinking I might have to resort to removing the dipstick and pushing a pipe on over the top of the dipstick tube and fill it from a funnel unless anyone else has a clever solution?
trev
PostPosted: Fri Aug 12, 2016 11:46 pm    Post subject: Reply with quote
there is no clever solution...
length of hose over the dipstick tube
half an hour to fill the oil Sad
Smoothlookinbay
PostPosted: Tue Aug 16, 2016 11:33 am    Post subject: Reply with quote
Maybe try welding a plate into the sump to accept an oil filler tube like the T25 1.9 diesel "wedge sump"?
It WILL be ready for the summer, just like it was going to be ready for last summer. And the one before that...
trev
PostPosted: Wed Aug 17, 2016 9:28 am    Post subject: Reply with quote
Well the van is gone back to its owner now but afterwards I was thinking a better way would be to delete the crank vent pipe from the side of the block up to the valve on the cam cover and make a pipe to weld to the plate that would cover that hole.
