Landmaster Wannabe
Posted: Thu Jun 01, 2017 9:13 pm Post subject: Smiths Speedo |
Evening All,
I'm thinking of fitting a Smiths Digital speedo to my Bay as the original is on the fritz.
I 've changed the front tyres and consequently the speedo is not reading correctly .
I've had a go at recalibrating it, but still not really happy with the accuracy.
I have an RJES loom with a VSS mounted on the back of the speedo, the Digital clock uses a similar set up, so ill end up with two sensors mounted between the clock and the cable.
My question is, have any of you guys done it,?
I'm worried that the cable will get its knickers in a twist as i'm asking it to drive two sets of magnets. Everything works really well at the moment and i don't want to mess it up, so any advice/experience would be much appreciated. Also they're not cheap !!
Thanks |
Posted: Sat Jun 03, 2017 11:02 pm Post subject: |
I have a smiths digital speedometer. Well it's an analog display but driven via my speed sensor. I can't remember what it's called but looks similar to the Porsche gauges. I want to say the smiths international range???
Anyway it reads any signal input. It's calibrated by driving one mile and it counts the VSS pulses.
So rather then fit a second VSS it will use the signal wire from the RJES VSS and will display an accurate speed. Mine is spot on with a sat nav and iPhone. _________________ Think......
Landmaster Wannabe
Posted: Tue Jun 06, 2017 9:40 pm Post subject: |
| Thanks for the reply, so what we're saying is that I just need to use the one VSS to tell the Subaru ECU that i'm moving and the speedo how fast!( subject to the calibrated mile business)? |
