Post your AWIC Air to water intercooler set ups
panel
PostPosted: Tue Feb 12, 2019 2:47 am    Post subject: Post your AWIC Air to water intercooler set ups Reply with quote
For those of you running a water to air intercooler.....what kind/brand/spec pump are you running? GPH etc.
-Are you running it continuous ? Or just activated at a certain temp?
-What size rad/condenser are you running? Fan on it?
-Are you also running a water tank as a reservoir or is there enough water in the system and just have a filler neck on the top of the intercooler itself?
-What kind/brand/size(core size) etc of water to air intercooler do you have? Barrel style or typical square/rectangle.
-What medium are you running? Straight water ? De ionized? Water wetter in there ? Antifreeze mix ?
EJ20 Turbo bus build
