79pickup Force Sensitive
Joined: 23 Dec 2015 Posts: 13 Location: Gosport,Hampshire
Posted: Mon Jun 20, 2016 7:45 pm Post subject: Alternator wiring quick question.. |
Just need an answer for this wiring. The loom has already been made up and although a lot of it is labelled I'm just trying to work out what's what and if it's correct. The two pictures below show the alternator wiring and it's the perfect length to bolt on and spade onto the starter motor. Is that correct? and if so where will the feed for the dash battery light come from?
Any help always appreciated guys!
bug12345 Force Sensitive
Posted: Tue Jun 28, 2016 4:27 pm Post subject: alternator wiring |
pretty sure its the one marked with a red arrow in the picture
[url [/url]
hope this helps  |
Posted: Tue Jun 28, 2016 9:41 pm Post subject: |
Ok that's worth looking into, cheers for the input!  |
Posted: Sat Oct 01, 2016 6:12 pm Post subject: |
It's been a while but I'm back onto the wiring side. So in the picture it shows a fat white and a thin white/black and these are both joined together. And
The other two fat reds off the post are also joined together. As previously said above they are the correct length to go the starter motor but not sure if this is coincidence. I'm thinking the fat reds should go to the battery via a hefty fuse? But what about the other two wires?
Help a dude out, so close to finishing haha!
P.s I've had it running just got to sort these final bits out  |
martix025 Wannabe
Posted: Sat Jul 20, 2019 3:18 am Post subject: Re: Alternator wiring quick question.. |
| 79pickup wrote: | Just need an answer for this wiring. The loom has already been made up and although a lot of it is labelled I'm just trying to work out what's what and if it's correct. The meilleurs credits immobiliers two pictures below show the alternator wiring and it's the perfect length to bolt on and spade onto the starter motor. Is that correct? and if so where will the feed for the dash battery light come from?
This is very interesting and the pictures are very expressive! |
