radiator on the roof
72panelvan
PostPosted: Fri Dec 29, 2006 12:04 am    Post subject: radiator on the roof Reply with quote
I thought I would share with you guys a brainwave I had the other day which entails mounting the radiator on a roof rack! If you boxed it in neatly in period luggage it would look pretty inconspicuous and I'd imagine pretty effective. Simply route some tubing up one of the air intakes and it would also eliminate any tubing under the van which could get caught going over something!
I was thinking it might be hard work for the water to get pumped up onto the roof but i guess it would be a natural heat cycle where the hot water/gas would rise naturally and then the cooled stuff would flow down.
Anyone seen an effective radiator on the roof?
Tom
famous phil
PostPosted: Fri Dec 29, 2006 1:23 am    Post subject: Reply with quote
Hello a few years ago the was one just like you describe , at bug jam ,
you would think that the water would flow , if the system is bled ok then it should not need to pump up , as the cooler water falls what might be good is stainless tube roofrack , that is the cooling rad , only thing is the cost ,
PostPosted: Fri Dec 29, 2006 1:34 am    Post subject: Reply with quote
Neat idea wouldn't want it to leak or burst though :smt088
famous phil
PostPosted: Fri Dec 29, 2006 2:05 am    Post subject: Reply with quote
no but think that the spray would end up on the rear window , same as when a pipe blows in engine bay , another reason for looking in rear veiw mirrow ,pluss warning lights
does the stick get any bigger at 300 posts , this is it
72panelvan
PostPosted: Fri Dec 29, 2006 2:49 pm    Post subject: Reply with quote
My dad kept on suggesting making the roofrack out of tubing to act as the radiator but I thought it was a lot of work with little control over the cooling.
famous phil
PostPosted: Fri Dec 29, 2006 3:57 pm    Post subject: Reply with quote
thats why it would be a good idea to fit a small rad & fan (micra or polo ) on the return , fit it in the engine bay should be just enough to keep your kool , in a jam
72panelvan
PostPosted: Fri Dec 29, 2006 4:06 pm    Post subject: Reply with quote
Yeah would be doable and pretty unique!
PostPosted: Mon Jan 01, 2007 2:54 pm    Post subject: Reply with quote
Afraid not... 500 is the next milestone Grin keep postin
Cleverchap
PostPosted: Mon Jan 01, 2007 6:27 pm    Post subject: Reply with quote
Check out this site.
Its how I first came across water cooled motors in buses about 7 years ago Wink
http://www.blabberon.com/whati.html
The Roadcow '71 Bay has a roof mounted radiator and might be of use if you do decide to go for it
72panelvan
PostPosted: Tue Jan 02, 2007 2:13 pm    Post subject: Reply with quote
Thats a really informative site - if i go ahead with it I'd aim to make the rad a little more discreet!
Good to know it definetely works with the rad on the roof though.
Tom
72panelvan
PostPosted: Tue Apr 24, 2007 3:29 pm    Post subject: Reply with quote
Just an after thought with this idea, but i remember reading somewhere that the expansion tank needs to be higher than the radiator? Is this true?
Tom
