Porka gauges
PostPosted: Tue Jun 05, 2007 11:05 am    Post subject: Porka gauges Reply with quote
Got mi gauges, yey!
Posche 924.
Any one got a pin out for the petrol/lights etc? There's a circle of 12 pins (maybe 13) numbered 1 - 12. What goes where?
Next Qs:
Is the fuel tank gauge compatible with a late bay sender?
Is the water temp gauge compatible with the VDO 40-120C sender, if not what do I need? The Porsche's gone now so robbing it isn't an option.
trev
PostPosted: Tue Jun 05, 2007 11:32 pm    Post subject: Reply with quote
I've got those gauges in my bug. I opened up the multi-purpose gauge and traced all the tracks on the PCB to find out what the pins did but later found a pin-out diagram on pelicanparts.com to suit. The early 944 had the same gauges so look under that too.
the fuel gauge works fine with the '73 standard bug sender so will probably work fine with the bus sender. Can't say for the water gauge though...
AMBROSIA
PostPosted: Tue Jul 10, 2007 3:35 pm    Post subject: Reply with quote
I have 944 gauges fitted to my 72 bug.
The fuel gauge does work but I ran out of fuel when it was reading 1/4 tank so be careful.
I have bought a 944 sender and am looking at possibly fitting it.
Otherwise I guess some electrical wizardry will be required.
PostPosted: Fri Oct 22, 2010 8:40 am    Post subject: Reply with quote
Ha this is proof that I can use the search button.
So two years on how are you guys getting on with your gauges?
I too have these 924 gauges on the self at home and I'm contemplating whether or not I'll use them.
I read that the Fuel gauge is potentially an issue, how have you guys got on with them?
The speedometer I have appears (to the untrained eye) to have some type of speed sensor at the back. This is a small circuit board with two wires coming out, underneath this boards is a round metallic wheel, could be magnetic dunno? Is this what I think it is?
These gauges will be a pain to fit into my Type three but if I knew they would definitely be up to the job then I'm prepared to have a go at fitting them.
Cheers
B4Tfink
PostPosted: Fri Oct 22, 2010 10:54 am    Post subject: Reply with quote
reading this:
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/124982-chip-back-my-speedo.html
seems its for a mpg gauge!! (you wont want one of them)
dunno if it can be adapted to a vss with a flux capacitor or two.
1988 T25 EJ25 n/a.. it just makes more sense that way..
PostPosted: Fri Oct 22, 2010 11:54 am    Post subject: Reply with quote
How the hell are you gonna generate the 1.21 Gigawatts of electric to power that !
1983 VW Golf GTI CAMPAIGN
PostPosted: Fri Oct 22, 2010 12:08 pm    Post subject: Reply with quote
Lightening
PostPosted: Fri Oct 22, 2010 12:10 pm    Post subject: Reply with quote
B4Tfink wrote:
reading this:
Well that certainly answers the question about the circuit board then.
PostPosted: Fri Oct 22, 2010 1:43 pm    Post subject: Reply with quote
Kai wrote:
Lightening
Good luck with finding when and where that's gonna happen Wink
PostPosted: Fri Oct 22, 2010 2:11 pm    Post subject: Reply with quote
Courthouse Clocktower
10:04PM
November 12 1955
PostPosted: Fri Oct 22, 2010 2:25 pm    Post subject: Reply with quote
10:04PM
November 12 1955
Alot of use that is in 2010 .. what you want is summit you can bung your waste into that'll generate that sort of power ! otherwise good luck with getting yer hands on some uranium !
PostPosted: Fri Oct 22, 2010 2:51 pm    Post subject: Reply with quote
That's easy..... I already work for the Russians. We've got it lying around the office
